3 members (David Bush, 52Carl, Jon G), 136 guests, and 13 robots.
Topics128,078
Posts1,056,029
Members48,433
#929010 03/20/2013 1:37 PM
Does anyone have a napa/autozone lower rad hose number for a 1956 GMC 100 with L6?
My truck came without one autozone is not showing a lower rad hose on their computer...typical
Alex
"If you can't fix it with a hammer, you've got an electrical problem."
best thing to do is make a 'pattern' with a piece of stiff wire and take that with the length measurement to a parts place that has a catalog from Dayco that shows shapes and dimensions - I think you might find one, but you might also be stuck using the flexy corrugated universal type, exact pre-shaped replacements for some applications are no longer made
3B Offline
Hy Cajunhcm, I could not find a molded hose listed for the lower rad hose you are seeking, just a piece of 1 1/2" straight hose. That got me wondering if maybe the bent part was pipe originally, and it was connected to the engine by short pieces of hose and clamps, hope that helps.
