0 members (), 200 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#92889 09/23/2002 10:16 PM
An update on my turn signal problem. Had an earlier post saying they do not cancel. I bought a new canceller , installed it and nothing changed. A visual inspection of the other parts seemed ok, but I didn't take them apart from the innards of the steering column. This is on a 1966
3/4 ton p/u. Anything I should look for that I missed to resolve this?
I didn't take the other items in the steering column apart cause I wasn't sure I could get them back together. At least right now, I have turn signals, I just have to remember to cancel them manually. So...... help.
#92890 09/24/2002 8:31 AM
WHich part did you replace? are you referring to the round part that slpis over the steering shaft?
there are cancel springs.They fit into the plastic switch assembly.There are left and right springs which should be available at the auto-parts store.
Do you happen to hear an occaisional crunching noise whe you turn the steering wheel?
#92891 09/24/2002 2:22 PM
I installed the part that goes underneath the steering column. Its the canceller. Are you sure there are springs on the 66 truck, and if so, what will they look like? I havent't heard any crunching type noise when I turn the wheel.
Would anyone have a drawing of how all the parts
go together in the column, so once I tear it down, I can get it back together. Or,can someone out there draw me a simple sketch of the innards.
That would really help, or if all else fails, show me where I can get a book that has that info in it. Ill probably need it for other adventures along the way. :-)
#92892 09/24/2002 2:54 PM
I believe there are replaceable springs on the part that the turn-signal lever ataches to.They are a little round wire looking piece which has a little hook on one end and it snaps in place and that the cancel cam bumps on the loop(circular part) to cancel the switch.
#92893 09/24/2002 3:05 PM
Email me.I will send you a picture of the switch and the spring I am referring to.
#92894 09/29/2002 6:22 PM
Did you figure out the Turn signal cancelling problem?
If not, email me.I will send you a pic of the turn-signal switch.
