1 members (Hotrod Lincoln), 153 guests, and 6 robots.
Topics128,268
Posts1,058,379
Members48,485
#928742 03/19/2013 3:56 PM
I'm looking for a source for the spring clip that holds the lock cylinder in the door of my 1946 Chevy. I have the original lock and it works just fine, but the spring clip that holds it in the door is missing. None of the parts suppliers I have checked have them without buying a lock. Does anyone know where I can get one? Thanks in advance.
If you can find an Auto Parts Distributors dealer/user in your area you might score one that way. Check out the catalog/pdf and if you have the part #'s it might help the local guy with the order... it's a big catalog.
Call the 800 number on the home page for a reference to someone in your area. good luck
Give me ambiguity
or give me something else
Hmmmm. Maybe some Dorman Help! product?
Ed,
CASO gave you the link to Au-ve-co, Go to it.
Second column half way down see key blanks.
Click on it,scroll down almost to bottom.
There,s Your Clip.
steve sr.
