1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello just taking things apart to get ready to paint the engine and notice the tube which protruds through the block which I assume it to drip oil on the timming gears is crimped closed or almost closed is this the way it should be or should it opened back up to the round shape of the tube thx for any help could not tell anything from pictures in the manual | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you look on the side of the tube you will see a small hole, that is where the oil comes out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Thx Dave I'll take a look | | |
