7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk), 126 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Does anyone have a picture of a stock rear end/Leaf spring setup. Trying to figure out if mine is actually the original or not. I added a pic of mine to my photobucket link. Thanks Steve
3100?
It looks like you have a helper/auxiliary spring set.
That was not a GM option.
It looks like a 3100 could have had optional heavy duty rear springs (1 more leaf, I think) but no auxiliary springs are listed for 3100/3600.
Aftermarket auxiliary springs were available (from JC Whitney, as one example).
thats what i suspected now I need to figure out if the rear end has been changed. Thanks
I uploaded another picture do you have any idea what i may have I may need to replace the bushings or at least the rubber spacers appear to be at the end of their life
I'd say you have the stock rear someone added helpers to sometime in the last 60 years, so you need whatever stock parts are available for those that are worn out
thanks for the help, much appreciated. Steve
My '50 3100 was set up the same way.
1950 3100 all original for now
