0 members (),
171
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92752 08/24/2005 11:42 AM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Just found out that my rear drivers turn signal does not work while parklights or headlights are on....it only works while all lights are off. what could cause this? :confused:
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#92753 08/24/2005 1:31 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Check the ground on that taillight. Brian | | |
#92754 08/25/2005 12:44 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | ground is good...still no signal flash when all lights are on.
Blue 50
#92755 08/25/2005 3:15 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Perhaps one filament is touching the other filament inside the bulb. Try replacing the bulb.
Gord 1954 1/2 ton 235 4 speed
#92756 08/26/2005 1:46 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | yup sounds like that rear bulb is shorted to the tail light.. uhhhhh bet when it blinks when the tail lights are off,,it blinks on the tail light filament and not the turn stop light... and it isnt as bright..?? hence when lights are on its burning all the time allready it wont blink cuz its hot all the time......
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#92757 08/27/2005 1:13 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Or maybe the taillight circuit is connected to the bright filament, and the turn signal on the dim?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
