0 members (), 202 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
#92752 08/24/2005 11:42 AM
Just found out that my rear drivers turn signal does not work while parklights or headlights are on....it only works while all lights are off. what could cause this? :confused:
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#92753 08/24/2005 1:31 PM
Check the ground on that taillight. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#92754 08/25/2005 12:44 PM
ground is good...still no signal flash when all lights are on.
Blue 50
1950 3100 w/57 235
#92755 08/25/2005 3:15 PM
Perhaps one filament is touching the other filament inside the bulb. Try replacing the bulb.
Gord
1954 1/2 ton 235 4 speed
#92756 08/26/2005 1:46 AM
yup sounds like that rear bulb is shorted to the tail light.. uhhhhh bet when it blinks when the tail lights are off,,it blinks on the tail light filament and not the turn stop light... and it isnt as bright..?? hence when lights are on its burning all the time allready it wont blink cuz its hot all the time......
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#92757 08/27/2005 1:13 AM
Or maybe the taillight circuit is connected to the bright filament, and the turn signal on the dim?
