7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP),
111
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, has anyone installed the IFS Heidts Mustang II 2" Drop Spindles on an art deco truck, specifically 41, 42, 46? Will they fit? Did the front drop 2"?
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I used the TCI front end basically the same but not the 2 inch drop spindles. Unless you want the belly rubbing the ground I do not think you will need the 2" drop. The standard spindles will bring it down nicely. | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | How about just the spindles? Chevsofthe40s has the Mustang II Drop Spindles for $190 for the pair, it says "Uses all stock rotors, bearings, calipers, etc. making it easy to install" Chevsofthe40sHas anyone just tried to install the spindles without the complete Heidts suspension system?
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | the way i am understanding the ad it is a up grade to the mustang ll kit they sell not for a stock front end | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | How about just the spindles? Chevsofthe40s has the Mustang II Drop Spindles for $190 for the pair, it says "Uses all stock rotors, bearings, calipers, etc. making it easy to install" Chevsofthe40sHas anyone just tried to install the spindles without the complete Heidts suspension system? When they say it uses all stock rotors, bearings, calipers, etc., they are referring to the Mustang II pieces, as the truck already needs to be converted to Mustang II. There is no way they will fit your front end. The best way to lower your stock front end is with a dropped axle or removing leafs. | | |
