Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (baldeagle), 118 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#92662 08/17/2005 2:11 PM
I am coverting to 12 volts and while checking the tech tips instructions, saw that there is to be a "standard ignition" installed in the gas gauge line. What does this instuction mean? FYI- This is a bone stock resto.
#92663 08/17/2005 2:17 PM
I
I Offline
It is a resistor to drop the voltage for the gas gauge.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#92664 08/17/2005 2:21 PM
yes, not really clear, eh?
I think if you follow the ((*)) to the bottom of the page, the "Standard Ignition" means you use an ignition resistor for the dropping resistor in the gas gauge line, as in:
"Part# EL110 Voltage reducer (Light duty for gas gauge)"
might be a brand name, but ask the parts store about a light duty ignition resistor
