1 members (Ponchogl), 130 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#925991 03/09/2013 10:02 AM
Going to check out the motor for the first time today. What type of compression should I be seing if it's in decent shape?
I would say 125-175 psi. It is more imporant for the numbers to be close from hole to hole than it is for the actual number. If the numbers are within 10 psi, you have a great motor, if one cylinder reads 55 and the next reads 150, you will need to do some work.
my 228 after 28000 miles had 95 accross the board and mine is in good shape.
Thanks guys. I need to do some more work, got it cranking but not good enough for a full test.
