7 members (Steelonsteel, dt235sd, klhansen, Charles in CA, BarryP, Wally / Montana, 37 GC),
139
Mod | | | Forums66 Topics128,142 Posts1,056,782 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Still new to the site and new to restoring my 55 GMC series 2 that my wife got from her father. In 1983 he rebuilt the truck, and put in a Chevy 350 from a '77 blazer.
I've now been through 3 OEM fuel gauges and have been testing them using a standard 12v battery. I have not had a chance to pull the sending unit out of the tank yet.
My question (and this may be stupid) - but since the fuel gauges were originally made for a 6V system, will they even work on a 12V system? It just doesn't make sense that all 3 of my gauges are bad.
1955 GMC 100 Series 2
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If the truck originally had a 6 cylinder engine it originally had a 6v positive ground electrical system (GMC had standard 6v positive ground in 6 cylinders trucks through all of 1955). If the truck was originally equipped with a V-8, it would have had a 12v system. ( see page 20) How many cells in the battery? Do the lights work? | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | The truck is a rebuild, it now has a V8 with a 12v system. It originally had a 6 cylinder with a 6v system.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3 OEM gauges? For a 6v 6-cylinder or for a 12v 8-cylinder?
| | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | I've tested 3 gauges, all on a 12v battery and none seem to work. That led me to thinking that maybe the gauges only work with a 6v system. My next step is to buy a 6v battery from wal-mart and test the gauges with that.
http://www.flickr.com/photos/71945287@N03/8505891142/in/photostream/
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the way to initially test the fuel gauge starts with resistance checking of the sender, if you haven't included the sender in your testing, how did you test them? - you've likely burned out the 6V positive ground gauges using 12V directly to neg ground on them
Bill | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | You'll need an adapter to use the original - to reduce the 12v to a 6v. They are available for around $15 from many parts suppliers.
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | With a GMC you can just get a 12 V gauge from a later truck. I put one from a '59 in my '54. | | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | GMTk I have the same truck....I used a resistor I got from Patrick's on my fuel gauge. Reduces the voltage from 12 to 6 volts. http://www.patricksantiquecars.com/articles.htmlBut Cletis has the right idea, if you can find one! Oh, and pull out that fuel sender, I'll bet you find it's corroded. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks Marc and tclederman - part ordered. I also plan on pulling out the sending unit and checking it from there. My wife thinks I'm crazy for all the work just to be able to use the original gas gauge....
| | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | You state you have been through 3 OEM fuel gauges. If you have not, don't buy 6V fuel gauge, purchase a 12V replacement. Then no resistors, no scabbing or bandaids.
See:http://www.americanclassic.com/asp/dyncatv2.asp?which=amclsall&p1=initial&p2=Speedometer+and+Gauge+Items&iyear=1955&ytype=to&exyear=1955 | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks to all for the help. I send all the gauges off to Bob's Speedometer repair in Michigan. All 3 were dead. He fixed one and it's not installed. Replacing the sending unit today so I'm hopeful that will solve the problems. Thanks again for all the advice and help. Not sure what I would do without this forum.
