3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#92539 08/04/2005 6:43 PM
I rebuilt my 46 1.5 Ton and kept the 6v system. A fresh and new 235. Generator, 6v coil, new points, condensor, plugs, wires, etc.
BUT, I do not have a resistor. Do I need one?
And exactly how do I hook it up if I do?
AND is there a 6v Resistor or are all the same?
Timmer
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
#92540 08/04/2005 7:22 PM
Resistors are only required to prevent cooking 6 volt components with too much voltage. Usually points, gas gauge, heater, and radio. They are only necessary if you do a 12 volt conversion.
You Tube
#92541 08/04/2005 10:11 PM
On a 12V. system with conventional points, a resistor is required to drop the voltage at the coil + terminal to about 9.5 volts to keep from burning the points. Your 6V system doesn't require it, and it wouldn't run right if you installed one.
