| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Does anyone know from experience, how similar the front axels (1.5-2 ton) are from art-deco, thru task force? What years are the parts interchangeable, and thru what years are the widths the same. I have an AD front axel I could use in a 41, but not sure if they are the same thing? Thanks in advance! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tomcoe, according to my parts book the 1 1/2 ton front axle is the same from 1941 to 1951. Do you know what year and size of truck your axle is from? | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Awe sweet. Yes, it is a 1950, so we should be good. Does that mean hub to hub is the same, bearings brakes, etc? That would be nice.
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Oh, size. The 41 is a 1.5 ton, and I think the 1950 is a 2ton. The axels look the same but it is hard to tell.
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | ooops...axle. I'm a numbers guy. Grammar and spelling, not so much.  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Your 41 might have had a lighter axle than the 50 2 ton, although the whole thing ought to interchange. If they have the same kingpin diameter you could swap spindles and all the other stuff between axle beams.
Grigg | | |
