1 members (baldeagle), 98 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#92263 07/06/2005 6:27 AM
I have a non functioning temp gauge in my '54 GMC 3/4 ton which I assume is a capillary unit, (the tube is severed midway down). My truck has a chevy 235 or 261-not sure.
Does anyone know how the capillary system works? Also, to keep my original gauge, or one that looks original, what is my best option? I've heard the Chevys used an electrical sender & gauge.
I'd like to get this working before the temp gets to 102 outside. I'm happy to say that this is the only gauge no longer functioning.
Thanks for any input.
#92264 07/06/2005 1:35 PM
I think you are going to have to contact one of the venders that restores gauges. I have not heard of anyone fixing this problem on there own. Sorry I don't have better news for you. Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#92265 07/06/2005 2:51 PM
the capillary gauges are not "home repairable" - as Brian sez, there are places that restore them, also places where you can buy repro replacements
#92266 07/06/2005 6:27 PM
I have read reports of folks fixing these. They buy a new capillary type gauge, immerse the bulb in dry ice, and connect the new tube to the old gauge. Never tried it myself but it seems workable.
Jason
#92267 08/09/2005 5:14 AM
Junior Member
Junior Member
.I guess this answers my question,I have a broken capillary tube on my 40's temp gauge.So if it's not repairable, how does a shop repair one?I'm pretty handy with working on small items(25 years experience building and repairing micro electronics), so where does one get a new tube?
#92268 08/12/2005 1:36 AM
The cap tube gauges contain a gas similar to Freon that expands when it's heated by the coolant, and the pressure moves a diaphragm connected to the gauge needle. While it might be possible to cool the gas in the gauge enough to solder the capillary tube to the old gauge without losing the gas (or liquid), it would be difficult, if not impossible to get exactly the right volume/pressure to make the gauge accurate. I'd leave the job to the professional gauge rebuilders.
#92269 08/18/2005 8:06 PM
You can pick up a reproduction guage with the correct color face and needle for about $49.00 from Jim Carter's (items REME925-930). There is a $30. core charge. I think chevyduty has them as does other places like chevs of the 40's etc...
