| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92179 06/21/2005 2:52 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I got a couple OE radios,& a service manual. If I buy a signal generator off ePay could I possibly repair my own radio? Anyone here ever do any work on old radios? I won't pay $400 to redo an AM radio that will be useless in a few years anyway. Anyone added satellite radio to one? Should I just hack away & install a CD player & get over it?? Need some tunes,,,Brian | | |
#92180 06/21/2005 2:56 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brian - if you've some experience in electronics you may be able to find and fix the problem, but your real problem will be finding the parts that'll need replacing - frequently the main problem w/ the old radios is the vibrator, if you can find a way to check it, or just a known good replacement, try that but don't need to 'hack' anything to just hang a cd under the dash Bill | | |
#92181 06/21/2005 3:10 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I fabricated a cover plate to go over the existing original holes for the stock radio, and mounted my CD/radio in the glove compartment..Speaker boxes mounted under the seat..Everything out of sight, and works real well..Don't hack the dash, you'll regret it later..Steve | | |
#92182 06/21/2005 5:06 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I cut my other 64 for a DIN radio w/speaker under the seat, it was already cut some, looks fine & works well but this truck still has the delete plate. Hate to be the one who hacks it up, this truck has never had a hole drilled anywhere. I have a couple radios for parts unless the same part always goes bad....Brian | | |
#92183 06/22/2005 2:19 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | |
