3 members (RoadsScholar, Gdads51, Gray_Ghost), 120 guests, and 4 robots.
Topics128,078
Posts1,056,021
Members48,433
#921726 02/21/2013 4:52 PM
Anyone know the skinny on what's necessary to swap one into a slightly-off-topic '76 Chevy G10 van??? It has a well-worn 350 4-bbbl and TH350 in it now. Rather than spend the money on a rebuild or a reman engine, I was thinking of finding a wrecked truck or van with the 5.3L auto for a complete drivetrain swap. Anyone have any experience with this swap, or the same eng/trans into an older Chevy?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
Sounds like a neat project. I'm not real familiar with the LS motors, but I can't see any reason it wouldn't fit. GM used to put big blocks in vans. I've seen LS engines stuffed into just about everything. Finding a wrecked van with an LS drivetrain would probably be the way to go.
Good luck.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Check with Summit or Jegs. I beleive both places have conversion motor mounts that allow the LS engine to be mounted on the earlier Smallblock frame mounts.
Bill Burmeister
Kinda tricky part is how are you going to deal with the electroinic fuel injection (EFI) and coil packs?
Lots of options from running carb and distributor to EFI on carb intake manifold to aftermarket wiring harness and computer.
I plan to run stock wiring harness and computer and stock fuse block and just power the fuse block and it works like a 2003 Silverado (as soon as I set up an OBDII port for Mr. Goodwrench, then any GM dealership should treat it like a late model and debug and wrench on it). So that's the plan--I have not done it yet.
R-Bo
1966 GMC 305V6 in the family
R-Bo #924288 03/02/2013 7:59 PM
R-Bo, the electronics part is actually the simplest part of the swap: make sure you get the computer and harness that go with the engine-trans combo, have computer reprogramed and harness modified by a good shop, and it is plug-and-play! And not necessarily more money than switching to carb and distributor.
I have dealt with a place called Speartech for all this: friendly guy, great service.
For swap with these LS engines, read the LS1Tech forum, they have a section about non-stock installations.
'57 Chevy Suburban; '70 Chevy Impala.
