8 members (carbking, Gdads51, Wally / Montana, klhansen, NJC, 2-Ton, 55shaker, Joe H),
46
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Anyone know the skinny on what's necessary to swap one into a slightly-off-topic '76 Chevy G10 van??? It has a well-worn 350 4-bbbl and TH350 in it now. Rather than spend the money on a rebuild or a reman engine, I was thinking of finding a wrecked truck or van with the 5.3L auto for a complete drivetrain swap. Anyone have any experience with this swap, or the same eng/trans into an older Chevy?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Sounds like a neat project. I'm not real familiar with the LS motors, but I can't see any reason it wouldn't fit. GM used to put big blocks in vans. I've seen LS engines stuffed into just about everything. Finding a wrecked van with an LS drivetrain would probably be the way to go.
Good luck. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Check with Summit or Jegs. I beleive both places have conversion motor mounts that allow the LS engine to be mounted on the earlier Smallblock frame mounts.
Bill Burmeister | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Kinda tricky part is how are you going to deal with the electroinic fuel injection (EFI) and coil packs?
Lots of options from running carb and distributor to EFI on carb intake manifold to aftermarket wiring harness and computer.
I plan to run stock wiring harness and computer and stock fuse block and just power the fuse block and it works like a 2003 Silverado (as soon as I set up an OBDII port for Mr. Goodwrench, then any GM dealership should treat it like a late model and debug and wrench on it). So that's the plan--I have not done it yet.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | R-Bo, the electronics part is actually the simplest part of the swap: make sure you get the computer and harness that go with the engine-trans combo, have computer reprogramed and harness modified by a good shop, and it is plug-and-play! And not necessarily more money than switching to carb and distributor. I have dealt with a place called Speartech for all this: friendly guy, great service. For swap with these LS engines, read the LS1Tech forum, they have a section about non-stock installations.
'57 Chevy Suburban; '70 Chevy Impala.
