3 members (Woodcmiami, Cosmo, 1 invisible),
75
Mod | | | Forums66 Topics128,150 Posts1,056,991 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | OK folks i need some schooling.I have a ford mustang II front end. I'm looking at replacing the front rotors,from what i have found is that the mustang II was four lug.The rotors i have are five lug with a 5 x 4.5 bolt pattern.this is the pattern i want matches the rear and also five lug.My question is how do i order or replace them? they always ask for year make and model engine size etc...? are all the ford rotors that are five lug and 5x 4.5 all the same? Can I just pick any year model and order from that? I know you can order any bolt pattern that you want. I have the bolt pattern I want just need to know how to order or are they all the same? Thanks brake-less and clueless | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | | | |
