4 members (Southerntruck, 5cameo8, Jack Ryan, Bill Hanlon), 124 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
b10
Offline
Does any body know where to buy a pack of wire locks to replace the ones in Betsy. A few looked flatten out. Lifters work good now after i cleaned them. and i am worried about the locks.
You are not going to find those serviced separatly and they may
have been made specificly to fit the lifter to GM specs.
But.....you may be able to find a retaining ring at McMaster
Carr that will work:
http://www.mcmaster.com/#retaining-rings/=lj5v6k
DG
Denny G
Sandwich, IL
b10
Offline
Thank you,I will contact them now .
Once the lifters are installed and adjusted the lock rings are doing nothing. The piston will be kept well below the lock ring.
My Blog
b10
Offline
I just do not want one of them (flat ones) to snap. So do not worry about it .
If they are worn the lifter was not adjusted correctly.
As I said before, if adjusted correctly the snap ring does nothing. It is mainly there to hold the piston in place while out of the engine and when backing off the lifter during adjustment.
My Blog
