9 members (TexasJim50, klhansen, Gdads51, J Lucas, Stovebolt48, Hotrod Lincoln, tclederman, GusG, Peggy M),
115
Mod | | | Forums66 Topics128,089 Posts1,056,422 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Does any body know where to buy a pack of wire locks to replace the ones in Betsy. A few looked flatten out. Lifters work good now after i cleaned them. and i am worried about the locks. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You are not going to find those serviced separatly and they may have been made specificly to fit the lifter to GM specs. But.....you may be able to find a retaining ring at McMaster Carr that will work: http://www.mcmaster.com/#retaining-rings/=lj5v6k DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Thank you,I will contact them now . | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Once the lifters are installed and adjusted the lock rings are doing nothing. The piston will be kept well below the lock ring.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | I just do not want one of them (flat ones) to snap. So do not worry about it . | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If they are worn the lifter was not adjusted correctly. As I said before, if adjusted correctly the snap ring does nothing. It is mainly there to hold the piston in place while out of the engine and when backing off the lifter during adjustment.
