5 members (klhansen, Otto Skorzeny, TUTS 59, dt235sd, 1 invisible), 146 guests, and 3 robots.
Topics128,095
Posts1,056,480
Members48,444
TF original pattern.
Do they have to small rectangle pattern? Or just the same thing all the parts places have?
Wow I like your truck, is it factory stock?
Mine has small rectangles, near the seat they go side to side, and toward the firewall they go front to back. (Does that make sense? Not sure how to describe it)
The truck is frame-off restored back to nearly stock specs; orig colors, orig drivetrain, orig suspension, added power brakes (all drum), but has stereo hidden in glove box, polished stainless bed strips and Ash wood in bed, Aftermarket wheels w/ nice radial tires and LED tail/brake lights (to hopefully keep from getting rear-ended.
very snazzy truck!!
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
That sure looks like it. Very nice job. What was used on the top of the dash for paint?
One problem the link for classic parts says out of stock.
I replied to your PM.
The top of dash is just semi-flat black chip guard textured paint from a spray can. I repainted it several times till I was happy with the texture. Practice with it on scrap first, it comes out really fast and thick!
Nice job on the truck. I like the color.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
I need a floor mat for my 1941 1 1/2 ton large truck, the problem is I'm in New Zealand and it's right hand drive so I need a mat the correct size for a large truck and without the pedal cut outs so i can do the cut outs here on the right. Any ideas from anybody? thanks
if you can't fake it with the partially cut ones available everywhere, you're stuck with the generic chunk of material offered, which you could probably find at an upholstery shop there or even some matting from a local flooring supply
Moderated by  ndkid275, Phak1
