3 members (wilbur53, 2 invisible), 71 guests, and 3 robots.
Topics128,109
Posts1,056,572
Members48,448
#919979 02/15/2013 7:30 AM
Finally made it to the rear brakes on the 57 GMC 370 LCF. Got all the rear wheels off and trying to get the brake drums off. I have the T-150 rear axel-2 speed. My manuals show removing the 3 countersunk small screws and the drum should slide off the lug bolts. Got the screws out but drum won,t budge. Sort of afraid to use heat. I have sprayed so much penetrant and may get the brakes on fire. Thanks for any advice.
Wayne.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Tap on drum with hammer, left side, right side, top, bottom, repeat, repeat, repeat until the rust gives up! Do this on the outer flat areas, not on the edges because you may break the drum.
Also, back off the brake shoes as they may have worn a groove in the drum.
I tried to back off the adjusting wheels, but they were frozen up. Finally I just removed the axel and complete hub-drum assembly. Slid right off that way.
Guess now I can use heat to separate them for easier installion.
One strange thing, every thing looked ok except for a leaking seal,and all 4 shoe return springs were broken and laying in bottom of the drum. Don't understand why all 4 were broken, they were shiny and not rusty looking.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Many of the larger drum/hub assemblies the lug bolt had long splines on them and would go through both the hub and the drum. So to separate the drum from the hub you may have to knock out the lug bolts to do so.
The screws held everything together while the lug bolts were put into place.
A lot of the newer hub/drum assemblies can be separated easily, but most of the older ones have to have the lug bolts removed to separate them.
Ah Ha, that explains why I was getting nowhere. The service manual only says the drum slips over the lugs, and shows its 2 separate parts. Thankx.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
