7 members (Otto Skorzeny, Phak1, Guitplayer, Perro, greenie-reddy, Hush, 1 invisible), 159 guests, and 6 robots.
Topics128,108
Posts1,056,228
Members48,436
#919886 02/14/2013 6:46 PM
I have a 1963 C-10 frame with a 1985 C-10 front clip bolted to it was 6 cyl now 283 the bell housing bolts to the frame the 6 cyl mounts don't fit I used the mount plates from the 85 the engine seems to be high in the front if i set a level on valve cover I have to lift the back 2 inches to level out . Here is my question what degree should the engine set at?
Dado #919887 02/14/2013 6:48 PM
The carb mounting surface should sit level.
