0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#91978 07/12/2004 6:28 PM
hi all the bolters out there!just as the subject states the amp meter needle flutters back and forth every once and awhile while driving.is this a bad sign of anything?it seems to be charging fine other than that. :confused:
#91979 07/12/2004 9:43 PM
H Online: Content
Is it an original DC generator/regulator system? The mechanical regulators have a habit of developing dirty points, and can cause the ammeter fluctuations you're describing. The points can be cleaned, but resist the urge to use a file, or even sandpaper on them! A piece of white business card, or a file card is just the right roughness to polish the points. Disconnect the battery wire from the regulator first, because accidentally pushing the cutout relay points closed with the engine stopped will cause them to stick and burn.
#91980 07/13/2004 1:21 PM
yes it the original generator Jerry. that was just the kinda info i was looking for thanks.i will take a peek. thanks for the words of caution on cleaning them. george. smile
#91981 07/13/2004 4:33 PM
H Online: Content
On most of the regulators, the points contact with a slight "wiping" action to be self-cleaning. Even a little roughness from filing or sanding will cause problems. I think most of them have pure-silver contacts, so they're pretty soft.
#91982 07/13/2004 4:34 PM
Also check the wire connections on the back of the guage. I once had one that was a little loose and would do the same thing. Make sure they're clean/tight.
