1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#91924 10/05/2002 8:32 PM
I installed one of those hi-amp alternators in my 6 cyl 63 Nova. The generator light is on at idle and slowly dims and goes out at 50mph. Is that normal? Thanks!
Jim
Jim
Is it a one wire alternator?
And how many volts are you getting at idle compared to higher RPMs?
Its an externally regulated alternator.
How do I determine how many volts its generating? Where do I test? Thanks.
Jim
Jim
It is probably best to test voltage both on the back of the alternator (batt. post) and across the battery terminals. Ultimately you need to have alternator output voltage reaching the battery, or within .5 volts or so. If you are losing 2.0 or more volts between the alternator and the battery, there is a bad connection which will cause more problems later. The alternator should be putting out 13.5 to 14.5 volts.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Anonymous
Unregistered
Anonymous
Unregistered
Jimfred! Why did ya go " private" ?? wink
You mean on eBay? Cause some pond scum seller posted offensive feedback after ripping me off; and eBay refuses to remove the insults.
Jim
