5 members (Hotrod Lincoln, Gdads51, Gray_Ghost, David Bush, Gib70), 118 guests, and 0 robots.
Topics128,051
Posts1,055,735
#91901 08/10/2003 6:33 AM
Does anyone know of a after market 12 volt electric wiper motor that will fit in the header panel of a 46 chevy
#91902 08/11/2003 7:44 AM
Apprentice
Apprentice
Just received my first catalog for my project...
Jim Carter shows p/n WW350, an electric wiper motor, bolt in, to fit '39-'46. Switch is extra. Others may also have it, but I haven't stocked my wishbook shelf, yet.
Kurt
When I find out what I'm doing, I'll let you know if I'm in too deep.
#91903 08/12/2003 6:14 AM
Thanks for the info Kurt
#91904 08/12/2003 4:15 PM
Stuart- I haven't seen the on that Jim Carter has, but Mighty Wiper makes one that will work but at $120 for the motor, wiper arm and blade it was a bit too much for me. What I did is to buy a wiper motor and arm from JcWhitney about 20 bucks if I remember right. The motor will fit inside the header panel but you will have to fabricate or buy a blank cover for it. The original one with the recess will hit the motor. Then you drill a hole in it for a switch (you can get one that looks similar to the original wiper pull knobs) leave the switch on the motor in the on position and wire up the new pull switch and your good to go.
I haven't installed mine yet but I have checked that it will fit and will work fine.
Good Luck
George
#91905 08/12/2003 10:11 PM
You can also get a double action fuel pump and keep the orginal vacuum wiper motor. The double action has a vacuum side to aid in windshield wiper operation and eliminate the stopping of the wipers when climbing a hill or accelerating. Used a many of one and work good.
#91906 08/12/2003 10:33 PM
Thanks for all the tips.
Senior Chief I have mounted the body on a 76 5/4 ton frame,350 with a hydroboost brake system so I should have plenty of vaccum to run the two stock wiper motors, right ? Thanks Stuart
