1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#918754 02/10/2013 1:22 AM
How fast at what rpm for what gear ratio?
Engine RPM / gear ratio = tire RPM
Pi x Tire diameter in inches x RPM of tire = inches per minute x 60 = inches per hour.
inches per hour / 63360 = miles per hour
Pi = 3.1415926
Rear end gear ratio is multiplied by the transmission gear ratio.
The gear system is a torque multiplier. With zero mechanical losses in the system, the HP will remain the same from Flywheel to the axle shafts, since that never happens rear wheel HP is always less than engine HP.
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
http://vexer.com/automotive-tools/speed-rpm-calculator
Heres what I like to use because its easy to check rpms in all your different gears and at different speeds.
Truckrolet #919217 02/11/2013 10:05 PM
This is the calculator I use;
http://www.roadranger.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf
It is actually for Diesel engines, but if you double RPM, it will double the MPH or you can use the formula at the bottom of the page.
