7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#91861 06/02/2003 3:20 AM
I have a 72 chevy pu and want to move tank to rear of truck,I have a 87 suburban tank that is going to fit good ,will the sender in the 87 tank work with the 72 gage ? If not what do I need to use?
#91862 06/02/2003 5:46 AM
It all depends on the depth of the tank. The sending unit should float at 90 degrees to read half-full ... if the tank is 12 inches top to bottom, then the sending unit needs to be 90 degrees at 6 inches ... if your "new" tank measures the same, top to bottom, as the old tank, then you should be okay.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#91863 06/07/2003 10:52 AM
Check to see if the resistance readings are close to the same. May be able to get the spec from a GM dealer, or you can test each gauge
