| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91861 06/02/2003 3:20 AM | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I have a 72 chevy pu and want to move tank to rear of truck,I have a 87 suburban tank that is going to fit good ,will the sender in the 87 tank work with the 72 gage ? If not what do I need to use? | | |
#91862 06/02/2003 5:46 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | It all depends on the depth of the tank. The sending unit should float at 90 degrees to read half-full ... if the tank is 12 inches top to bottom, then the sending unit needs to be 90 degrees at 6 inches ... if your "new" tank measures the same, top to bottom, as the old tank, then you should be okay.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#91863 06/07/2003 10:52 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Check to see if the resistance readings are close to the same. May be able to get the spec from a GM dealer, or you can test each gauge
