4 members (Maybellene, klhansen, 2 invisible),
87
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91830 01/28/2002 3:17 AM | Joined: Jun 2000 Posts: 3 Junior Member | | Junior Member Joined: Jun 2000 Posts: 3 | I've got a new Sony radio hooked up in my 57' GMC which has worked fine until recently. The strangest thing is that once the motor RPM's reach a certain level, the radio loses power. Once the RPM's come back down, the radio pops back on. The power wire to my radio is connected directly to my "kill" switch which is also connected to the ignition. I can't understand why the radio would be effected by RPM's? It is not vibration, ....I am convinced it is electrical. Thanks for any advice you can give! The rest of my elctrical system is perfectly fine. It is 12V. :mad: | | |
#91831 01/29/2002 11:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Your voltage regulator is either fried or set too high. Most new radios shut off if the voltage gets too high. Check to make sure that the voltage never goes above 14.
#91832 01/30/2002 5:15 AM | Joined: Apr 2000 Posts: 6 Member | | Member Joined: Apr 2000 Posts: 6 | Megga dittos. I used to install those buggers for a living. You must be crankin out some serious voltage to make her shut off.
Beat it to fit...Paint it to match.
#91833 01/30/2002 5:18 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | | | |
#91834 01/31/2002 10:08 PM | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | It could be the flugal valve! :p
Thomas Mott 1949 GMC 250 1957 Dodge COE c-700 1959 Chris Craft 17' w/big journal 327 for more power
#91835 02/02/2002 12:21 AM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Flugal valve? Thats right next to the radiator on a VW bug, isn't it? chip  :p :rolleyes:
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#91836 02/02/2002 3:46 AM | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | Just above the muffler thrust bearing I believe? :confused:
