1 members (Otto Skorzeny), 85 guests, and 1 robot.
Topics128,162
Posts1,056,941
Members48,458
i removed my manifolds cause the exhaust flange was busted and i noticed that the freeze plug above the throttle link bell crank has a tiny crack in the center and a few drops sitting tricking out.
can i replace my manifold then deal with the plug or do i need to take care of that first?
i think found a thread on here saying to use a dome plug and not a cup? is this correct
3B Offline
Hy drew_vigil, I would want to deal with the "freeze plug" with as much room as possible, and use the same style plug as the one you remove. A little sealer around the outside edge when you install the "freeze plug" wouldn't hurt. To remove the plug, just drive a chisel or screwdriver into the center of it and pry it out, hope that helps.
is this the one I want?
brass vs steel?
Expansion Plug Type : Cup Type (Deep)
Material : Brass
O.D. (Inches) : 1.625"
O.D. (Metric) : 41.275 mm
