0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 6 New Guy | | New Guy Joined: Jan 2013 Posts: 6 | I am putting a relatively mild 350 in my 52 chevy 3/4 ton. i want to put in a 5 speed. i have been looking at either a t5 or an nv3500 to put behind it. I am going to use the truck as an everyday driver/lite hauling. I was wondering if it anyone has put either one behind a 350, i know the nv3500 is stronger, but is it as easy to put in as a t5? | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | The NVG3500 (a.k.a. HM-290, 5LM60) was used in chevy / GMC 1/2 tons starting in 1988 used behind 4.3 V6, 5.0 5.7 V8. Bell housing is part of the front casehalf, Hyd. clutch, same 10 spline clutchshaft.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2013 Posts: 6 New Guy | | New Guy Joined: Jan 2013 Posts: 6 | Sounds like it would be an easy bolt up and use then if I am reading it correctly.
Thank you so much for the info. | | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | the only thing with the NV3500 there's no possible provisions for mechanical speedometer
50 chevy 3100
