10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 94 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#917013 02/03/2013 7:56 PM
Are the motor mount holes on a 250 the same distance from the back of the motor the same as a small block ?? I need to know if the cross member I bought for a small block is close enough to work on the 250.. Thanks
Since I bolted a 350 in place of a 250 with the same mounts I would say yes.
