11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | does anybody know if a bellhousing from a 216 will fit a 250?
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Yes and No!
Yes I know the answer and No it won't fit. A bellhousing from a sbc or bbc will fit on a 250. If placing a 250 in a pre 1954 truck, The rear engine crossmember will need some work. It may be possible to swap the original crossmember with one from a 54-55.1 truck. The later crossmember will line up with the "angled" bellhousings of the post 1954 trucks. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | No it won't. Only 216, 235, and 261.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | ok can someone tell me what kind of bellhousing I can use for this 250 and do I need to use my adapter plate to use my t-5? | | |
