7 members (jay d, 55shaker, KEVINSKI, J Lucas, NofoolN, 3B, TPR57C),
199
Mod | | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91655 12/01/2004 4:37 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I just restored my 54 pushbuttion radio but can't figure something out.
I have 2 wires coming from the radio. One wire goes directly to the ON/OFF Volume pot - Is this the 6v Power wire?
The other runs to a 1"x2" metal plate mounted on the inside top of the tuner case which then goes to the ON/OFF Volume pot. What the heck is this animal? Perhaps from the lightswitch to feed the dial light?
I apparently replaced both wires some time back with 14 AWG, so wire size doesn't give me any clue. I did have the radio working several years ago but can't remember the hookup.
Thanks for any help! | | |
#91656 12/01/2004 4:44 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | One should be power in and the other goes to a speaker terminal. Both the radio case and the other speaker terminal ground to frame. | | |
#91657 12/01/2004 6:07 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | jgalt,
Are you referring to a '54 car radio (there were no pushbuttons on the 54 truck radio)? Does the radio mount in the dash of your truck?
Most likely the two wires are for the radio power and radio light bulb (as you stated). Both are 6v and you should be easily able to test which serves what purpose (ground the case and feed 6v to each wire (one at a time). If you have a good light bulb, you will soon figure out the leads.
The truck radio had two additional leads that were soldered to the speaker (mounted on a plate on top of the radio). The 53 manual-tune auto radio that I have seen has a phono-plug outlet for speaker connection (this plug may not be original). How do your speaker wires connect to the radio? Are you able to post a picture?
Good luck, Tim | | |
#91658 12/01/2004 6:10 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | On this radio, the speaker is connected thru an RCA jack. Someone on another forum suggested that the other wire might be for the radio dial light. This makes sense, so I'll dig in that direction.
I still wonder what the heck the metal plate is for. It would act as a capacitor or perhaps noise supressor I'm thinking, dunno. | | |
#91659 12/01/2004 6:36 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | On my '51, one is for the light, the other for power. On mine, the one for power, has an in line fuse. I hooked them both up to a hot source. Cecil........ | | |
#91660 12/01/2004 7:09 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | My radio is from a 54 car. Does anyone know the correct connection point for the lamp wire?
I wonder if it should go to the light switch assembly - to the terminal which feeds the instrument lamps. In this arrangement, the radio lamp would be dimmable.
Hooking both leads to power would certainly be a decent solution, the radio will see only occasional use I'm sure. Especially so after the 6 volt MP3 sound system plan is implemented :p .
Thanks for the replys! | | |
#91661 12/01/2004 8:25 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Your correct in that is suppose to go to the light switch assembly. I have mine going to the accessory terminal on my ignition because the light only goes on when the radio is on. I won't be using it that much anyway. I have a tough time getting to the light switch right now with everything hooked up. Cecil..... | | |
#91662 12/01/2004 6:21 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | One lead is for the light. Normally this is connected to the instrument lamps for dimming control. The other is the power that runs the radio. The metal plate is a capacitor, sometimes called a chassis capacitor. The wire coming from the metal plate should have a small coil formation about an inch long, 1/2" in diameter. Together they form a filter to stop the electrical noise from the rest of the system from getting into the radio. | | |
