0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#916476 02/01/2013 3:59 PM
Today I installed a new horn button. Simple, right? Then the horn wouldn't stop blowing (Murphy's law at work). So, I quickly disconnected the battery, then disconnected the wire from the horn. Upon reconnecting the battery I could hear the horn relay clicking, so I disconnected the horn relay. Now my Amp gauge doesn't work.
I'm assuming the horn problem is due to the insulating material (thin cardboard like material) flaking and coming out from underneath the horn contact plate as I tweaked the prongs so the new horn button would slip on. Is this correct?
Also, how/why is the Amp gauge affected by the horn relay?
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Sir Searchalot
Sir Searchalot
Get an analog horn. (squeeze bulb).
Not sure what truck we are talking about.
If it is a 59 chevy, the horn wire comes down the steering column and exits to go under the dash and through the firewall. You should be able to simply unplug the wire where it exits the steering column.
As far as the horn honking all the time, Usually that is the upper mast bearing failure. Did you remove the steering wheel?
yes, you likely caused a short in the horn circuit messing with the contact, the button should supply a ground to the relay only when you push the button - as daddy points out, you can reconnect what you disconnected and unplug the horn wire where it exits the column to see if that's the problem
"why is the Amp gauge affected by the horn relay?"
because you have something wired wrong in the circuit involving the relay, the regulator, the ammeter and the light switch, which are all interconnected, or you also disconnected a wire from the regulator .... look at the wiring diagram in your shop manual and check your wiring [this one will work if you don't have a manual]
Thanks for the help.
Bigbad: Yes, my questions refer to the '59. I did not remove the steering wheel. I will unplug as you suggested until I get the problem resolved.
Bill: It looks as though I need to pull the steering wheel and check the contact. Thanks for the diagram. There may indeed be something wired wrong since the PO did some rewiring to convert to an alternator.
Steve
Oldbolter
dont forget, use your brakes before the horn
Redryder pix
My Hotrod
