8 members (Otto Skorzeny, Shaffer's1950, SlimSix, Hotrod Lincoln, TrknGMC, homer52, 2 invisible),
79
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | Been going thru my NOS 235 hot rod engine parts and found a camshaft kit springs lifters push rods. the cam paper had faded out and is unreadable. It is a Sig Erson 110515 290F. If i my memory is correct it is 515 lift 290 duration ??. I also have a new set of jahns 60 over dome pistons and a harper 3x2 manifold. Might build another 235 as i have a good block and a few 848 heads left. | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | I called Erson , 458 lift 292 duration, 242 duration at 50, 110 lobe . | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That's a nice "forgotten" find. Stuff I come across in my garage is usually not that good.
Drew
| | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | I built several of those old engines back in the 70's and have a few good parts still laying around still might build another or just let someone else enjoy them.
I parked my 1950 chevy fastback in 1979 due to farming and a business that took all of my time.we brought it from the farm a couple of years ago and put it up inside. Last week i put a new fuel tank in fuel lines brakes ect and got it going this week, i might try to post a video on you tube of it running. It was over .060 deck and head milled timing gears relieved, 59 deg curve in the ignition 2 large one barrels on an offy , full length tuned headers and a cam almost identical to the Sig. It ran better than anyone expected with a 3.73 rear gear and a Muncie rock crusher. | | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | Here is a short video of it running.http://www.youtube.com/watch?v=kWg6ltSmeK8 | | |
