0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#914334 01/24/2013 6:09 PM
lar
Offline
I use4d a camaro subframe in my 40 truck . would the standard camaro coil springs work ? Installing sbc v8
Thanks Larry
lar #914347 01/24/2013 6:32 PM
if it was a v8 car they will work
lar #915217 01/27/2013 10:30 PM
I agree.Use springs rated for a v8 car
lar #915229 01/28/2013 1:35 AM
Sir Searchalot
Sir Searchalot
If you look up coil springs for say a 1982 Camaro at O'Reilly's using a V8 as your vehicle, you will see, under compatibility, almost all engines use the same standard spring.(sping)
lar #915274 01/28/2013 7:58 AM
They've worked fine in every truck I have sub framed.
