6 members (Donf, FAST55, Danielbolt, cmayna, rfs56trk, Oswald), 67 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
#91512 01/14/2005 2:08 AM
Junior Member
Junior Member
Just got a "new" '59 and the gas gauge pegs to the full side. Seems to be the opposite problem that other folks are having. What causes it to read full when I turn the key?
#91513 01/14/2005 2:23 AM
You have a short to ground somewhere in the wiring between the gauge and the tank, or the sending unit itself is shorted out.
Paint & Body Shop moderator
#91514 01/14/2005 3:37 AM
Tab Offline
4onthefloor, speak truth.
I am betting that it's your sending unit. Pull that sucker out and do some tests. It's been a while since I've had that problem but the last time I managed to fix my sending unit by soldering the broken pieces. Start by taking it out of the tank and moving the float rod and see how that changes the gauge. It's possible that the short may be at the terminals on top of the gauge. Also make sure that the rubber gasket is in good shape.
delete my account and pictures
#91515 01/14/2005 9:57 PM
Riding in the Passing Lane
GM gas gauges are wired so when the circuit is open the gauge will go way over to full. Ground the wire at the sending unit & see if the needle goes to empty. If it does your sending unit is bad or not grounded. If it doesnt change you have an opening in the wire between the gauge & sending unit. smile
1972 Chevy c10 Cheyenne Super
#91516 01/15/2005 1:25 AM
Are you sure, bender?
Mine goes to empty when I disconnect my gauge wire.
#91517 01/15/2005 5:25 AM
Agree here. No contact from sending unit to guage registers full and in a hurry!
#91518 01/16/2005 4:32 PM
Tab Offline
Get a spare sending unit. Hook up the wires and move the float arm, noticing the needle deflection. This will tell you if it's the sending unit or the gauge. I'll bet, sending unit. They go bad from water condensation in the tank, and rust. Also the brass floats can develope a hole and get flooded. If you need an entire sending unit, and can't find the right one for your tank, fear not. I soldered and wired together the parts from a totally different sending unit on mine and IT WORKS.
