6 members (LAROKE, Otto Skorzeny, Chip O, Hotrod Lincoln, Gdads51, 1 invisible), 80 guests, and 2 robots.
Topics128,131
Posts1,056,369
Members48,441
WONDERED IF OVERSIZED TRUCKS CARRY SAME AS 1/2 TON SIZES GRILLE AND HOW TO TELL? OR MEASURE? ANY HELP GLADLY APPRECIATED,,THANKS BOLTERS
Only the fenders are different. The wheel well openings on the 1 1/2 ton and up are bigger than the 1/2 ton. The rest of the sheet metal is identical.
1939 Chevy 1/2-Ton Pickup Truck
More pix on Photobucket
1946 1.5-Ton Chevrolet Stake Bed
1940 Chevy Sedan - Frame-off Restoration
I believe the opening on the front of the fender where it goes over the frame is different. Also the height of the running board under the cab.
1939 Chevrolet Stake Truck
Thank you very much fellas.. big big help
