10 members (JW51, 68ironhead, baldeagle, Guitplayer, 2-Ton, walter74, Eisenholtz, Peggy M, joe apple, WICruiser),
82
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 20 New Guy | | New Guy Joined: Nov 2012 Posts: 20 | I'm going to be pulling and rebuilding the 235 in my '50. At the same time I want to yank the 3 speed out and replace it with an auto. Whats the best trans for that? Gonna be a cruiser on all types of roads, rural and highway. I'm not opposed to changing the rear to make it work. I want it to have some get up and go, but also be economic to an extent. Waiting for your suggestions.
Eric
1950 3100 all original for now
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 700R4 is what you want, but it will take changing to an open driveline
Bill | | | | | Joined: Nov 2012 Posts: 20 New Guy | | New Guy Joined: Nov 2012 Posts: 20 | That's what I was lookin at. Maybe do a 10 or 12 bolt rear. Any specific year 700R4?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they were used about 82-92, and I've heard the later half were somewhat improved, but they're all the same gearing AFAIK .... for the rear you might investigate using a center section from a 55-59, I'm not sure if you need the axles as well, some of the AD series folks here could expand on that - you still need to weld up the 'pivots' on the torque tube rear, but it might make an easier change
Bill | | | | | Joined: Nov 2012 Posts: 20 New Guy | | New Guy Joined: Nov 2012 Posts: 20 | I assume they will bolt right up? Thanks for the info.
Eric
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rear gear will bolt in, not sure about the trans on the 235, but someone will know, others have done it
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll want the '85-'93, sourced from a full size truck, Caprice/Impala, or from an S10 with the 4.3 V6 option. All of those should work fine the available adapers. The '82-'84s should be avoided, unless a full rebuild is done first, including a pump replacement. The early 700R4 has a weak pump, and was known to lose pressure when in overdive. The later pump solves that issue. The '94 and newer (also known as the 4L60E/4L65E) are electronically controlled, and may not be desirable for use with an older engine.
Bill Burmeister | | |
