7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91423 06/18/2004 2:22 PM | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | hi stovebolters. please help! i should have left well enough alone! i have 56 shev stepside took instrument cluster out to clean glass lens and get template of the shape so i can make billet aluminum insert like no limit sells. every thing worked before taking cluster out including starting. went to hook every wire behind cluster back up and no i have no power to anything. including not starting. complete wiring system dead.original 56 wiring.only other wiring disturbed is the horn relay and heater connection unhooked. if the connection for the heater was touching bare metal when the battery was hooked back up would this have fried igniton switch resulting in no power everywhere?cleaned connections and replaced wire ends that is under positive side of starter by the switch there still no power.any help or sugestions would be great ps. the black and red wires that go to the ampmeter which goes towards side and which goes to pass.side of gage? DOH!I should have marked them | | |
#91424 06/18/2004 4:13 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I would check the back of the ammeter terminal for power first of all. Then test the other terminal of the ammeter for power. This other terminal "not the one coming from the starter" will pass the current to the B+ terminal on the key switch to give power to the truck. If you don't have power going from one terminal to the other on the ammeter then it's fried and you'll need another one.
Do some testing with a test light and see if you have power to the ammeter, the other side of the ammeter terminal and also down to the B+ terminal on the key switch.
Joe
Joe
#91425 06/20/2004 3:47 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The main feed wire on these junctions at the horn relay. You may have dropped a wire at the relay. take a test light & chase the cirquits. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#91426 06/23/2004 1:46 PM | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | thanks guys.i checked one of the connections on the headlight switch seemed to be the problem. | | |
