2 members (JW51, 78buckshot),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Had to replace pump on Betsy.Found one online.It came with paper gasket.It dripped near the long bolt hole so i took it apart checked it put (new gasket) back on same story.I remembered the old gasket was made of cork and really thick.Found some sheet cork made my own( X2)to get the thickness and used old fashion Gasket Shellac. No more Dripping. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you are using extra gaskets that are thicker I would check the pulley alignment. I wouldn't recommend a cork gasket for a water pump. Most auto parts stores sell gasket material that is of a good quality. Some of the re manufactured pumps do come with a poor quality gasket. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You might check that the bolt isn't bottoming out. The bolts from the factory are not standard length, they are special. Often they are misplaced and a hardware store replacement bolt is used in its place. With the lock washer crushed it appears that it's tight but in reality it is bottomed out just a fraction of a turn before it is actually tight against the pump body. This gives the impression that the gasket is bad and not making a seal or suggests there is a minute crack in the pump or block. You should not need a cork or thick paper gasket for the water pump a stock 1/32" gasket with Permatex #2 is perfectly adequate.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Thanks guys but no leaks yet and i will wait till pump goes bad to change it again.Bolt are not bottoming and have lock washers on all. | | |
