2 members (KEVINSKI, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | can anyone tell me the depth of a 1934 flywheel, from pressure plate mounting surface to clutch disc contact surface? need to be sure i don't have a mismatched fly wheel and pressure plate | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What model 34 do you have? Truck, Master, or Standard.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The parts book shows 1934 as one year only. There were also two styles, one with pressure plate guide pins and one without.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Know I wish I had a 34 flywheel to measure. I hope someone here can help out. You may want to ask over at the VCCA site, Link to VCCA .
