3 members (Bill Hanlon, ShopRag, 1 invisible), 67 guests, and 1 robot.
Topics128,049
Posts1,055,676
#913149 01/20/2013 2:22 PM
i been tuning my 235 in my 58 biscayne ,, i am real close , i am doing it by vacuum i have almost 20 on the gauge , i have the idle close to what i think and timing also , by the highest vacuum , but i still have a little popping in exhaust , just a little ,, whats the best way to adjust the carb , i have been screwing it in until it starts to mis and back it out a little ???
any input would be grateful
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #913153 01/20/2013 2:30 PM
Presumably, you are using the mixture screw to adjust the carburetor (not the idle screw).
I turn the mixture screw in until the engine runs roughly/slower. Then, I turn out the screw until it reaches maximum vacuum.
lilrobo #913154 01/20/2013 2:30 PM
I'm sure others will chime in, but I don't think 'popping' from the exhaust sounds like carb issues. Have you done a compression and/or leak down test?
Like I said, I'm sure others will have an opinion..
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
lilrobo #913160 01/20/2013 2:54 PM
i am on a fresh rebuild , i have did the timing again doing it to get the highest vacuum , it starts great and when given gas it takes it well with no hesitation , the popping is very slight but enough to know its there , the head was redone also and valves
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #913166 01/20/2013 3:03 PM
This is a hydraulic lifter engine, right? If not, how did you adjust the valve lash?
Also, is the carburetor recently rebuilt? The float adjustment might be a little off.
lilrobo #913171 01/20/2013 3:13 PM
no carb work at all ,, yes hyd lifters ,, i did by adjusting them until0 lash and i give them 1 turn more
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #913453 01/21/2013 3:42 PM
I'll bet your valves are too tight. I had the same problem on my truck. Ran good but popping noise from tailpipes, also was down on power. I found that you need to get engine to normal operating temp and THEN adjust the valves, solved my problem.
Good luck!
Darren
lilrobo #913460 01/21/2013 4:10 PM
ok i might have to try that ,, i need to let weather warm up a tad bit ,, what is your oct setting on ( 1/2 nut at bottom of dizzy )
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #913473 01/21/2013 4:54 PM
You set the octane selector to zero before adjusting the timing. The octane selector was useful when you bought different grades of gasoline and/or you were driving at different altitudes. You could fiddle with the octane selector and later set it back to 0 when you got home.
lilrobo #913620 01/22/2013 4:56 AM
Great thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
