| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | Hey Guys, I was looking at a truck recently that was advertized as a "1959 Apache Ranch Truck." The seller notes that it has a heavy duty bumper and diamond plating in the bed of the truck as these were original to 'ranch' models. Its a nice looking truck,has a 235 and 4 on the floor. I've just not heard that Apache came in a special ranch version. Anyone heard about a Ranch Apache. I'm no expert but from the looks of it I would say it is a 1959 Apache stepside... but I'm no expert on these old trucks. Love to hear what you think. Tx. PFT | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | First of all welcome to the bolt. To the best of my knowledge, 59 Chevrolet trucks came with a wood floor in both the stepside and fleet side models. It was not uncommon for a purchaser to put a steel plate in the bottom of the bed to protect it or cover the holes after the wood rotted out or got broken out. I have a 73 K10 that I did that to while the truck was fairly new to protect the wood. I would guess that you would find the wood bottom or what is left of it if you looked under the truck. Someone might know something I don't though. Jim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There isn't any special "ranch" model I'm aware of, there isn't a listing for it any of the spec guides. If it has diamond plate in the bed, it was added aftermarket, the factory bed floor would be wood, though it isn't uncommon to see these old trucks with a sheetmetal peice covering the wood floor. I'm inclined to beleive the bumper is most likely aftermarket as well.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as said above, there was no version called a 'ranch truck', and there was no 'Apache' [58-61 Chev light truck. 1/2T. 3/4T or 1T] that came with a metal bed floor, especially not diamond plate - when Chev started using metal floors they were wide ribbed sheet metal .... a rear bumper was an option, but not a "heavy duty" one .... use caution on that one if the seller is handing out that kind of BS
Bill | | |
