Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (68ironhead, Bill Hanlon, Waveski, Otto Skorzeny, Jon G, 2 invisible), 129 guests, and 6 robots.
Topics128,283
Posts1,058,513
Members48,490
#913220 01/20/2013 6:58 PM
I
I Offline
I just put a 53 235 in my 40 and I'm getting a zero pressure reading at the gauge.
I know that I'm getting oil up to the rockers so it would seem there's pressure.
Is there a way of testing the oil pressure and if so, what should it be?
You can buy a cheap gauge and thread it into the fitting at the block where the factory gauge is connected, or into the Tee fitting where the oil filter is (if you've got one). I bought a gauge at FLAPS for $6. It only reads to 50 psi, and that's fine.
Have you run the engine with the rocker cover off to see the oil? - Just curious, not being a jerk, as sometimes the distributer doesn't drop down enough to engage the oil pump. (Ask me how I know this!)
On my 235, I get 30 psi at startup idle, and then when the engine is warm, about 5 psi at idle, and 25-30 at speed (40mph). The pressure varies a bit with the outside temp.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
If it were me, I would pull the distributor and turn the oil pump with a drill. If that doesn't show pressure on the gauge I would check for a blockage wher the fitting comes out of the block. I have witnessed this problem when a buddy started his after he put it together.
1951 1 Ton Completed
I
I Offline
Thanks guys, I'll give the drill a try and see what I get.
I bought a "mechanic's" oil pressure gauge some time ago; with a set of brass adapters to allow you to put it into your current sending unit location. It's got about an 18" flexible hose on it.
I always use it for initial startups and breaking periods BEFORE I install any original/aftermarket/ gauges or idiot lights on my projects. (New or old, I have found that they are not always the most accurate....)
I ran it for about 150 miles on my last project (under hood) before hooking up aftermarket gauge. (Turned out to be almost exactly correct, whew!)
Also, while we're at it... I always compare temp gauge readings with an infrared/laser, hand held thermometer. This allows you to move it around and check temps all over the engine, radiator, thermostat housings, etc.
Got sick of inaccurate temp gauges! I hate when they erroneously tell you it's overheating and you are freaking out on a hot summer cruise!
