7 members (3B, 68ironhead, Jon G, 2-Ton, Phak1, 49nut, Gray_Ghost),
64
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i been tuning my 235 in my 58 biscayne ,, i am real close , i am doing it by vacuum i have almost 20 on the gauge , i have the idle close to what i think and timing also , by the highest vacuum , but i still have a little popping in exhaust , just a little ,, whats the best way to adjust the carb , i have been screwing it in until it starts to mis and back it out a little ???
any input would be grateful thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Presumably, you are using the mixture screw to adjust the carburetor (not the idle screw).
I turn the mixture screw in until the engine runs roughly/slower. Then, I turn out the screw until it reaches maximum vacuum.
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I'm sure others will chime in, but I don't think 'popping' from the exhaust sounds like carb issues. Have you done a compression and/or leak down test?
Like I said, I'm sure others will have an opinion..
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i am on a fresh rebuild , i have did the timing again doing it to get the highest vacuum , it starts great and when given gas it takes it well with no hesitation , the popping is very slight but enough to know its there , the head was redone also and valves thanks
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This is a hydraulic lifter engine, right? If not, how did you adjust the valve lash?
Also, is the carburetor recently rebuilt? The float adjustment might be a little off.
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | no carb work at all ,, yes hyd lifters ,, i did by adjusting them until0 lash and i give them 1 turn more
thanks
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I'll bet your valves are too tight. I had the same problem on my truck. Ran good but popping noise from tailpipes, also was down on power. I found that you need to get engine to normal operating temp and THEN adjust the valves, solved my problem. Good luck! Darren | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | ok i might have to try that ,, i need to let weather warm up a tad bit ,, what is your oct setting on ( 1/2 nut at bottom of dizzy )
thanks
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You set the octane selector to zero before adjusting the timing. The octane selector was useful when you bought different grades of gasoline and/or you were driving at different altitudes. You could fiddle with the octane selector and later set it back to 0 when you got home.
