| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91311 04/18/2002 11:17 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | I bought a turn signal kit a year or so ago, and just got around to installing it in my 41 Sedan. The kit came with a NAPA 550 12V flasher.
When first tried, the lights on the signal flashed away, and looked great. But nothing at the park or tail lights. Got the meter out and could detect a very small voltage pulse. Detectable voltage, but not enough to light the halogen park and tail lights. I figured flasher sat too long or something. I ran to the store and first tried a heavy duty electronic flasher. Had X-L-P tabs just like one I had. Nothing.
Went back and got a regular three prong flasher. Prongs were '+', 'L', '-'. Changed the wires with P to '+', and X to '-'. Park and taillights flash, but quickly. (Flasher flashes doublespeed when bulb burned out, but all my halogen bulbs are working fine.) Also, the turn signal doesn't light up and flash anymore. The hazards work fine. :mad:
What flasher can work! Thanks! :confused:
Jim
#91312 04/19/2002 8:07 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Well, I went out and bought flashers from several sources, and we have a winner!
Advance Auto Parts had the TRIDON Stant 12V 550. It not only flashes correctly, but doesn't have the problem I've seen before of the red indicator light staying on.
Now to run around returning flashers....
Jim
#91313 04/19/2002 9:28 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I had the problem of new 6-volt flashers blinking way too fast. I was at the local wrecking yard and saw a flasher hanging on a COE Advanced Design. The guy gave it to me for free. It's great. The new ones blinked way too fast. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
