1 members (Charles in CA),
87
Mod | | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Does anyone have a photo or diagram as to what the oil spray pipe should look like for a 235 six-cylinder engine? This is the small diameter pipe that is part of the rocker arm assembly. Mine is crimped and facing the rear of the engine and is located near the center of the rocker arm assembly.
Thanks for your help as always. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year 235? Have you checked the Shop Manual for that year? Here are some illustrations. | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Tim,
The engine is for my '58 Apache. Have some photos I will upload and let you know. Have not checked the shop manual, but will.
John | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John,
Do you need better illustrations than shown in two places on the link that I gave above? They are from the 1958 Shop Manual.
Yes, please post photos.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sounds like some backyard mechanic bent the pipe around for some reason John. The illustrations that Tim posted clearly show's what the oil connector should look like and how it is installed. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Here is some pic's of the one used from 1953-58 Connector 1959-62 were pinched off from the factory. One example
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is not a big problem using a pinched off tube on a 1953-58 engine. The biggest problem seems to be keeping the valve cover gasket from leaking with all the extra oil.
I see you have aluminum supports. That is only the second set I have seen.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I'm sorry. Please educate me on where the aluminum supports are in my two photos so I will know what you are talking about. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are 6 supports that the shafts go through and mount the assembly to the head. Example
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thanks. After rereading your comment and taking another look at my two photos I thought those were what you were referring to.
Looks like I will be buying a new oil connector. Somewhere along the way mine has gotten 'nibbled' off and partialy crimped. | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | TC,
What is the trick, actually the correct procedure, to removing the rocker arm shaft far enough to get the old bent/pinched oil connector off and a new one installed? I have a vision of valve springs going all over my garage and then be able to find the all but one. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John, Check out figure 16. The valve springs are held in place with caps and keys/locks. | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Tim,
Again thank you. I had visions of valve springs going everywhere. Have not had many motors apart myself.
With the valves being under different compression due to where the pistons are, some of the springs are going to have more force pushing up when I disconnect the hold-down blocks and again when I try to reassemble the rocker arm assembly. How do I get it all put back together? Is this a one or two-person job?
John | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John, For reassembly, you slowly screw in the 6 rocker-arm posts. You have to make sure the push rod ends stay in the ends of the rocker arms as you tighten down. Make sure you have the rocker arms in the correct order - try not to disassemble the rocker arms/springs from the hollow shafts/rods. The 1960 rocker arms drawings and instructions are on pages 8-9 and onwards. 8-11 and 8-12 have terse instructions and a few photos. | | |
